Troubleshooting website display or functionality issues in Edge on older Windows versions
This browser is no longer supported.
Upgrade to Microsoft Edge to take advantage of the latest features, security updates, and technical support.
Hello, I'm using MS Edge on my laptop and I'm having an issue with opening this website URL. I was searching about some information and visited a URL but there's issue telling you can't visit this URL now, can you please guide me if there is any issue in my browser ? Thanks!
Thank you for writing to Microsoft Community Forums.
I understand that you’re facing issues when opening websites on Microsoft Edge. I will certainly try my best to assist you with the issue.
For further clarity on the issue, please respond to the questions below:
We tried accessing the website you shared, and we were able to access it fine. Meanwhile, I would suggest you to follow the steps mentioned below and see if that helps.
Method 1: Use Private browsing
Try accessing the website using private browsing and see if the website is working fine. Refer the article Browse InPrivate in Microsoft Edge
Method 2: Clear Cache & Cookies
Try clearing cache and cookies of the browser and see if you are able to access the website. Refer the article Delete cookies in Microsoft Edge
Method 3: Reset Microsoft Edge
**Note:**This will reset your startup page, new tab page, search engine, and pinned tabs. It will also disable all extensions and clear temporary data like cookies. You favorites, history and saved passwords will not be cleared.
Let us know if you need any further assistance, we will be glad to assist you.
Regards,
Prakhar Khare
Microsoft Community - Moderator
I'm using the latest version of Microsoft Edge. URL is not opening only in Edge even I cleared my browser's cache and reinstalled too.
Try to clear browser's cache or install new version again, I hope you will find it working.
