Read aloud on Edge stopped working correctly after an update a month ago. Does anyone know how to fix it??
Anonymous
2024-12-29T10:12:51+00:00
About a month ago I noticed that the Read Aloud feature on Edge stopped working properly after an update. It starts reading but after the page turns the pages are cycling non stop. It keeps reading where I left off but the pages cycling is confusing. Does anyone know how to fix that?? I use Read Aloud for school mostly and it's been a hard month without it.
It has happened before, a few months ago and it fixed itself after a few days but it is not the case this time... Does anyone know how to fix it??
Microsoft Edge | Read PDFs | Windows 10
  1. Anonymous
    2024-12-30T08:27:06+00:00
    Hi, antonia .
    Welcome to the Microsoft community.
    We are able to reproduce your issue, which occurs in the Stable version of Edge. It might have been caused by a recent update (as many users have reported this issue recently). We recommend that you use the feedback feature in Edge by pressing Alt+Shift+I to report this issue to the developers.
    We also tested other versions of Edge, and it seems that the issue does not occur in the Canary version. Therefore, you can try using the Insider version to see if it works properly (you can try all three versions)
    Become a Microsoft Edge Insider | Microsoft Edge
    Best regards
    Tommy Jin | Microsoft Community Support Specialist
