Text and images is not displayed in edge
Anonymous
2023-11-01T09:31:40+00:00
Over the last few days, I have explained that text and images is not viewable in Edge on my Motorola G54 running Android 13.
I do not know if images actually load - sometimes I see a "placeholder" indicated by a dotted line - but text is white and therefor unledgeble, as background images and colours also does not seem to load.
When a word which was spelled wrong on a page showed a wave like red line underneath it, I tried to mark all text (copy function), I became aware that the text was actually there, which is why I conclude that all text must be white!
The issue is the same when I try to use Bing AI.
When I loade a website in Google Chrome, the page displays fine!
Anu suggestions?
Microsoft Edge | Website issues | MacOS
  1. Anonymous
    2023-12-21T12:48:17+00:00
    There is easy fix for this.
    Disable "#enable-gpu-rasterization" in edge://flags/#enable-gpu-rasterization
    When they fix it later on, then you can re-enable it.
    10+ people found this answer helpful.
  2. Anonymous
    2023-11-03T19:24:56+00:00
    Sorry for the late reply. Unfortunately, the troubleshooting steps that we can do for mobile apps are limited and based on the screeshot, it looks like its a bug causing this issue. I suggest submitting feedback to report this by tapping on the hamburger icon or 3 lines then select Send feedback. You can also use the link below.
    https://feedbackportal.microsoft.com/feedback/f...
    Kind regards.
  3. Anonymous
    2023-11-03T02:00:56+00:00
    Hi JC03,
    The first thing I did was to delete Edge and re-install it again.
    That did not help!
    About screen shot, here is how Microft.com is displayed!
  4. Anonymous
    2023-12-19T05:47:27+00:00
    I have the same issue on my moto g32. Clearing the cache and force stopping the app solves it temporarily, but it's a pain to do this everytime I've to use the app.
    Have submitted the feedback too last month, but no fix yet
  5. Anonymous
    2023-11-01T12:36:14+00:00
    Hi, LARSLEMMING.
    I'm Jen. I'm an independent advisor and would happily help you figure this out.
    To make sure I'd be sharing helpful advice, may I ask if this happened after udpating the app? Also, will you be able to share a screenshot?
