Edge read aloud feature for PDFs on android?
Anonymous
2023-12-18T13:04:34+00:00
I'm trying to use the read aloud feature on a pdf on the Android mobile version of edge but I cant find the option. I actually cant find any options it wont even let me highlight text. Is there a way that i can do this on android?
Microsoft Edge | Read PDFs | MacOS
  1. Anonymous
    2023-12-18T14:44:08+00:00
    Hi, I'm Elise, a fellow user like yourself and I'd be happy to help with your issue.
    Unfortunately this feature is not yet available on the Android mobile app, I can only suggest that you leave feedback on this using the in-app help menu.
    Please let me know if you need any further assistance.
    Kind Regards,
    Elise
    10+ people found this answer helpful.
