Opening and reading PDF files in Microsoft Edge on macOS
This browser is no longer supported.
Upgrade to Microsoft Edge to take advantage of the latest features, security updates, and technical support.
When I read PDF files using Edge on my Android phone, is there a way to adjust "something" so the text "fits" on the screen and is easily readable w/o the need to swipe, which for lengthly documents is painful.
MS Word has a feature called "Mobile View" that allows PDF files to "fit" and be very readable on the phone's screen.
Hi DaveLPG47,
Welcome to Microsoft Community.
Unfortunately, Microsoft Edge for mobile has limited functionality and adjustable configurations and does not include PDF-related configuration items.
Optimization of the product's functionality relies on customer feedback and investigation by the product team.
For product-specific feature suggestions, you can submit your ideas in the feedback option provided by the app.
If I misunderstand your situation, feel free to correct me and share the information.
Best Regards,
Kyo - MSFT | Microsoft Community Technical Support
