Managing media playback issues and settings in Microsoft Edge on Windows 11
This browser is no longer supported.
Upgrade to Microsoft Edge to take advantage of the latest features, security updates, and technical support.
I do not have any audio on my laptop. When I go to systems, sound, properties under general it says "dont allow" how do i change that
To change the setting that says "don't allow" under the sound properties in Windows 11, you can follow these steps:
services.msc in the Start menu, finding "Windows Audio," and ensuring it is set to start automatically.If you continue to experience issues, ensure that your audio drivers are up to date and that your audio device is properly connected.
