It sounds like you're experiencing a complex issue with your Surface Pro 8 where the battery is not charging despite being connected to power. Here are some troubleshooting steps and considerations:
- Check Power Supply and Connections: Ensure that both the original Surface charger and the USB-C charger are functioning properly. You might want to test them with another device to confirm they are providing power.
- Firmware and Driver Issues: Since you mentioned that several firmware components show a yellow warning in Device Manager and that updates fail due to insufficient battery, it could indicate a firmware issue. If possible, try to manually install the latest Surface firmware and drivers from the Microsoft website. This might require the device to be charged sufficiently, so if the battery is completely unresponsive, this step may not be feasible.
- Battery Hardware Check: Given that the battery is stuck at 0%, it could indeed be a hardware issue. This might involve the battery itself, the charging circuit, or internal connectors. If the device is still under warranty, consider reaching out to Microsoft support or visiting a service center for a hardware evaluation.
- Reset the Device: If you haven’t already, perform a hard reset by holding the power button for about 30 seconds. This can sometimes resolve temporary glitches.
- Check for External Factors: Ensure that there are no external factors affecting charging, such as dirt or debris in the charging port, which can impede the connection.
- Battery Report Analysis: Since your battery report indicates that the design capacity and full charge capacity are the same, it suggests that the battery has not degraded significantly. However, this does not rule out the possibility of a malfunctioning battery or charging circuit.
If these steps do not resolve the issue, it may be necessary to consider professional repair options, especially if hardware failure is suspected.
