Battery not charging due to firmware issue, unable to update the firmware because it requires 30% or above battery level
SWARN ZAILDAR 5 Reputation points
2026-02-19T00:56:30.3+00:00
Battery doesn't charge
Tried lot of stuff
Tried different chargers
tried USB c charger
Tried charging while staying in uefi
tried manually installing the firmware
Surface | Surface Pro | Power and battery
  1. S.Sengupta 30,501 Reputation points MVP Volunteer Moderator
    2026-02-21T01:56:19.3+00:00
    If your Microsoft Surface battery is not charging even after trying different chargers, USB-C, UEFI charging, and firmware reinstall — the issue is likely hardware related.
    Shut down.
    Hold Volume Up + Power
    Go to PC Information
    Check battery percentage.
    If battery % shows, there but not charging → software issue
    If battery % is stuck or 0% → battery or charging IC issue
    Open
    Device Manager:
    Expand Batteries
    Uninstall:
    Surface Battery
    Microsoft ACPI-Compliant Control Method Battery
    Restart
    Finally, If Surface works:
    Only when plugged in
    Shuts off instantly when charger removed
    then the battery is dead.
  2. kagiyama yutaka 1,990 Reputation points
    2026-02-19T01:00:11.3866667+00:00
    I think that batt fw’s jammed so the EC won’t pass any charge at all… sry u’re stuck w/ that. Only shot I know is a hard EC drain (pull AC, hold pwr ~40s), then hit the OEM charger fast and sometimes it leaks just enough % for the fw to run.
