Managing sound and video settings during Teams meetings and calls for optimal communication
Dear @Mahesh Kharel,
Based on the information you’ve shared, I understand how disruptive this is, especially for a high‑volume member services team. The symptoms you’re experiencing might happen when there are high‑usage Microsoft Teams Call Queue environments, particularly when using Attendant (ring‑all) routing.
To help narrow down the root cause, could you please help confirm the following details:
- Is Conference mode enabled on the call queue?
- Does the behavior persist if the headset is disconnected and audio is routed through the laptop’s built‑in speakers/microphone?
- Are users primarily working over Wi‑Fi or wired Ethernet?
Firstly, in this case, I recommend you try clearing the Microsoft Teams cache, as cached data can sometimes become unstable after client updates. For more information, please refer to Clear the Teams client cache
Moreover, according to my research, many other customers and administrators have reported improved stability after:
- Removing the distribution group from the call queue and adding agents directly by name, or
- Removing the distribution group from the queue, saving the configuration, and then re‑adding it (to refresh queue membership)
Important: Make sure both the caller and callee have a stable connection with adequate throughput.
For further troubleshooting, follow the steps in this article: Troubleshoot User Call Quality Problems and My calls or meetings keep dropping in Microsoft Teams
Given that the issue persists after extensive local troubleshooting and appears to correlate with the New Microsoft Teams update, I highly recommend asking your IT administrator to create a support request through the Microsoft 365 Admin Center for further investigation. This will allow the Microsoft support team to review backend service logs, client telemetry, and known product issues that are not visible from the tenant or endpoint side. For reference: Get support for Microsoft 365 for business
I understand how disruptive this is to daily operations, and escalating through the Admin Center is the best way to move this forward for deeper, service‑level troubleshooting.
Note: Please understand that as a forum moderator, my role is to provide general guidance and troubleshooting support. I don’t have access to internal systems or backend tools, and I appreciate your understanding of these limits.
I hope the information shared helps point you in the right direction. Please try the steps above and let me know if they work. If not, we can continue working together to narrow this down.
The first response may not always resolve the issue right away, but with your help and more details, we can work toward a solution.
Thank you for your patience and understanding. I'm looking forward for your reply.
