surface 7 pro+ wont start and does not go to recovery
djacco v/d Bosch 0 Reputation points
2026-03-25T10:36:37.2866667+00:00
My surface pro 7+ does not start into windows so I tried to boot into recovery but it will not do that. I made the recovery USB on my other computer (copying the files from the recovery zip to the root of the usb). I also can not get into the bios.
when I press power it starts with the surface logo (spinning circle) and then gives a message on the black screen "surface 7 pro device ran into a problem and needs to restart"
It will boot to windows 10 usb media but has an error when trying to install windows and i am back to where I was. It will also boot into a Hiren utility usb that I have but I don't know what tool to use to fix the problem (I checkt for disk errors but therre are no errors).
Can you please help me with this problem
regards Djacco
Surface | Surface Pro | Install and update
  1. S.Sengupta 30,501 Reputation points MVP Volunteer Moderator
    2026-04-07T02:57:19.0066667+00:00
    I shall suggest you go for a Clean Install.
    Visit:
    https://support.microsoft.com/en-us/surface-recovery-image
    Create Proper USB:
    Download recovery image for Surface Pro 7+
    Format USB → FAT32
    Extract ZIP → copy all files to USB root
    Insert USB
    Hold Volume DOWN + Power
    Release when Surface logo appears
    Choose:
    Troubleshoot → Recover from a drive
    Select:
    Fully clean the drive Reset or recover your Surface
