A family of Microsoft presentation graphics products that offer tools for creating presentations and adding graphic effects like multimedia objects and special effects with text.
Hi, Kenny Smith
It sounds like Copilot is creating the deck, but the handoff between Copilot, PowerPoint, and the connected cloud account is what’s failing. This can also happen when the wrong Microsoft account is active, required privacy settings are off, or the browser blocks the sign-in check.
Besides the solutions provided by the Q&A Assist, here are some suggestions you can try:
Make sure the exact same Microsoft account is signed into Copilot, PowerPoint, and OneDrive. If you use both personal and work accounts, sign out of the extra one first, then reopen PowerPoint.
In PowerPoint, go to File > Account > Manage Settings and make sure “Experiences that analyze your content” and “All connected experiences” are turned on.
If you’re using Copilot in a browser, allow third-party cookies, then refresh and try again.
In PowerPoint, go to File > Account > Update License, then check for Office updates too.
If Google Drive is part of the flow, it is recommended that you copy the source file into OneDrive and create the presentation from inside PowerPoint, instead of relying on the Copilot download button.
Thank you for your patience in reading, I hope this information has been helpful to you.
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment."
