Update. I think I found it.
In System >> Notifications I see a very weird, recently added facility that, apparently, allows rapid pop ups. In this case the popups were continuously popping up every 30 seconds or so. Clicking on any part of the popup caused Edge to open to some virus infested site. However, the instant I moved the slider switch to off position (see top entry under "Notifications from apps and other senders" in screen capture) all of the fake virus messages stopped.
This sort of thing never occurs with macOS. Mostly Windows has been good - but this is a work computer, so I don't do a lot of heavy internet surfing on this machine. It's a bit of rude awakening that some random entity can alter your computer with malicious code.
Although I've switched the malicious program off - how to I remove this? I'm assuming some type of malicious software is still in my system.
Windows Defender isn't giving any warnings - so that's good.
I'd really like to remove the offending code (uots-protect.co.in) that Edge allowed to be installed under the guise of detecting if I'm a human or not.
What a pain.
