Hi Phil Jenkins,
I can see that Q&A Assist has already shared some solid troubleshooting steps. In addition to those, since your headphones are working but the internal speakers are not, you may want to check a couple of things that are quite common on Windows 7 laptops:
First, try unplugging and re‑plugging your headphones a few times and check the headphone jack for dust or debris. Sometimes the system can remain stuck in “headphone mode” and won’t switch back to the internal speakers.
Next, open Playback Devices (right‑click the speaker icon > Playback devices) and make sure Speakers are set as the default device. If they’re not listed, right‑click in the window and enable “Show Disabled Devices.”
If the issue continues, reinstalling or updating the audio driver from Panasonic’s support site for the CF‑53 may help. On Toughbook models, missing or outdated audio or system interface (hotkey) drivers can sometimes affect speaker output even when the system doesn’t show as muted.
You can also select the Speakers device and click Test to check if any sound plays. If there’s no sound during the test, it may help confirm whether this is driver-related or a possible hardware issue.
I hope this gives you a few additional angles to try. Please feel free to share any updates or what you’re seeing and I’ll be happy to help you narrow it down further.
