Hi George Ioannou,
I completely understand your concern about only getting a few hours of battery life and noticing heat, especially on a brand‑new Surface. Just wondering, have you tried out the checks suggested by the Q&A Assist? And did anything improve?
If after applying all the recommendations, you’re still seeing short battery life and noticeable heat under minimal load, that’s not normal behavior for a new Surface. This usually points to either a firmware or driver issue, or a potential hardware fault.
In those cases, it’s totally reasonable for you to request device repair/replacement, especially since it is brand new. The good news is that this process is handled separately from the usual support line, so you won’t face the same situation as before:
- Refer to How to get service or repair for Surface - Microsoft Support
- Sign in at account.microsoft.com/devices/select-device-for-repair
- If your Surface Pro isn't registered yet, select Register device.
- If the device is already registered, choose it and click Next.
- Follow the instructions to complete your service order.
I wish I could provide more direct help, but if your device continues to perform below expectations, it may point to a hardware issue. Unfortunately, this is a user‑to‑user forum, so we don’t have access to device diagnostics or the ability to arrange replacements. I hope you can get the help you need.
