If possible, could you access msinfo32.exe in the search bar, take a screenshot, and post it here so I can see the desktop configuration?
If you have a GPU, could you tell me the model?
Thanks
This browser is no longer supported.
Upgrade to Microsoft Edge to take advantage of the latest features, security updates, and technical support.
I have just built a new pc and installed windows 10. Brand- frontech Model Name- MON 0052 moniter is built in speakers connect with HDMI cable I have tried adjusting the volume for the audio but audio icon is disable, device is not show any whare sounds & sound setting I've ran the audio tests and troubleshoots, reinstalled drivers, and even tried recovering the windows audio service - nothing.
Moreover, my PC shows me that there is no audio device. The device settings show no problems, I can't use the volume icon to move adjust sound or mute/unmute I've tried different HDMI cables, to verified that the audio does work on my headphones connected to my PC (I did try the audio with and without the headphones connected).
There doesn't even seem to be a detectable problem as far as the PC is concerned. What am I missing?
Thanks
On a new Windows 10 PC where the monitor speakers over HDMI do not appear at all and the volume icon is disabled, the issue is usually either:
Follow these steps in order:
If the volume icon is disabled and no device is listed, continue.
If the HDMI monitor does not appear at all, continue.
If updating does not help, reinstall the driver.
If rollback is not available or does not help, restoring from a system restore point created before the problem started is another option (see “Restore from a system restore point” in Recovery options in Windows).
If, after these steps, no device appears under Playback and Device Manager shows no audio controller at all, the issue is likely hardware (motherboard audio or monitor) and requires checking with the PC/motherboard vendor.
