Edge and Chrome issue with sharepoint auth
Imrinder Randhawa 0 Reputation points
2025-12-11T20:33:12.1533333+00:00
screenshot
Error: We couldn't sign you in. Please try again later.
Affected users: 20 and increasing
Edge and Google chrome both are giving the above error when some of our users try to access *.sharepoint.com. The browsers are configured in Intune. We have made no changes to policy in last 2 months. We have onedrive client and sharepoint drive mounte din file explorer, and that works fine.
It looks like the issue is related to everything sharepoint but not Teams, outlook on web, word etc. The issue started on Monday: 12/8/2025. Started with 3 users, the number has grown to 20 + users. The issue began when Edge was updated to version 143....66. The issue persist in google chrome as well, I am guessing edge uses chrome engine that's why they are linked. I have tested same users and same device with firefox, no issues at all. We reset the device and it worked for 2 hours then back to same issue, we tried another device that we wiped completely and reinstalled windows, issue persisted.
We have tried new profile, signed out of profile, tried signing back into profile, Inprivate mode, reset browser to default, clearing cache and all files
Microsoft Support is looking at sharepoint and M365 services but I think it is related to browser update. Please help!
Microsoft Edge | Install and update | Windows 11
  1. Restee Miranda 14,030 Reputation points Independent Advisor
    2025-12-12T20:22:01.9433333+00:00
    Here's a remediation guide for SharePoint sign-in problems:
    Cause: The issue isn't isolated to a specific device or browser cache, as it persists across devices and after OS reinstallation. The problem is most likely due to corrupted tokens or outdated session data in Azure AD/WAM, potentially caused by a recent Edge update.
    Steps:
    1. Check PRT Status:
      • Open Command Prompt as administrator and run dsregcmd /status.
      • Under Device State, confirm AzureAdJoined, SSO State, and PRT Status are all YES. SSO will fail if the PRT is missing or bad.
    2. Revoke User Sessions:
      • In Azure AD, go to Users > [Affected User] > Sign-ins and check for errors.
      • Under Authentication Methods, click Revoke Sessions to force a new token refresh.
    3. Remove Device Registration:
      • In Azure AD, go to Devices > [Affected Device] and click Delete.
      • On the device, run dsregcmd /leave, reboot, then run dsregcmd /join to rejoin Azure AD.
    4. Clear WAM and Credentials:
      • On the device, sign out of all Edge accounts.
      • Go to Settings > Accounts > Access work or school and disconnect the work account.
      • Open Credential Manager and delete entries for login.microsoftonline.com and sharepoint.com. Reboot and reconnect the work account.
    5. Test:
      • Sign back into Edge with the work account and test SharePoint in both normal and InPrivate modes.
    Optional: Policy Check
    • Verify the BrowserSignin policy is active for Edge and there are no conflicting Intune policies for cookies or SSO.
    If the problem continues after the steps above, there may be a WAM/SSO bug in the latest Chromium build. Report this to Microsoft, including logs from dsregcmd /status and Azure AD sign-in error information.
  2. Restee Miranda 14,030 Reputation points Independent Advisor
    2025-12-12T20:20:55.1533333+00:00
    Thanks for clarifying that, it’s an important detail. If the same user fails even in InPrivate on their own device, but another user works fine on that same device (even in InPrivate), then this is not a browser cache issue. It’s something tied to the user’s identity tokens or device registration in Azure AD rather than the local profile.
    Here’s what that tells us:
    • The problem follows the user, not the device.
    • Wiping the device didn’t help, so the corruption is likely in the cloud identity layer (Azure AD / WAM tokens) or Conditional Access session state.
    • InPrivate working for a different user confirms the browser itself is fine.
    Next steps:
    1. Check the affected user’s Azure AD sign-in logs for SharePoint. Look for conditional access failures or token issuance errors.
    2. Verify the user’s Primary Refresh Token (PRT) status with dsregcmd /status on their device. If PRT is missing or invalid, SSO will fail.
    3. Try revoking all sessions for the affected user in Azure AD and force reauthentication.
    4. If that doesn’t help, remove the user’s device registration from Azure AD and rejoin it.
    This feels like a PRT or WAM token issue triggered by the Edge update, but persisting because the user’s cloud session state is broken.
