Nikon Studio will not load on my Surface laptop.
Laurie Tonkin 0 Reputation points
2026-01-05T06:35:02.8166667+00:00
Nikon say problem is with Microsoft as Surface uses a different processor architecture which leads to compatibility issues. So question is, How, What is required to fix?ure
Surface | Surface Laptop | Install and update
    2026-01-05T14:17:40.9133333+00:00
    Hi @Laurie Tonkin
    Regarding your issue, this behavior is expected on some Surface models that use ARM‑based processors (such as Snapdragon). These devices run Windows on ARM, and while Windows can emulate many traditional desktop applications, some applications especially creative software that relies on specific codecs or low‑level components are not fully compatible unless the developer provides ARM64 support.
    In the case of Nikon NX Studio, the application is not currently provided as a native ARM64 version. While some Nikon components may install, NX Studio itself relies on certain libraries or components that are not fully compatible with Windows on ARM. As a result, the app may fail to install, not launch at all, or close immediately after starting.
    To move forward, you may consider one of the following options:
    • Use an Intel/AMD‑based Windows PC to run Nikon Studio.
    • Use ARM‑compatible photo editing software (such as Lightroom or Photoshop) that supports Nikon RAW files on your Surface.
    I understand this can be especially frustrating, since from a user perspective everything appears to meet the Windows 11 requirements, yet the application still doesn’t work as expected. For a long‑term solution, I recommend reaching out to Nikon Support and asking whether an ARM64 version of NX Studio is planned, as only Nikon can address this at the application level.
