Create Recovery Drive problem
Phil D 0 Reputation points
2026-05-01T15:53:33.77+00:00
Win 11 Pro.
New flash drive, 32GB, FAT32 format.
Appears on file explorer and is functional.
Attempts to create recovery drive using the published steps results in the drive not being 'seen' or acknowledged by the create recovery software. It just keeps asking for a flashdrive 32GB minimum.
Professional replies only.
Windows for home | Windows 11 | Recovery and backup
  1. Sumit D - IA 167.2K Reputation points Independent Advisor
    2026-05-01T17:12:55.7166667+00:00
    I suggest creating a Windows installation media instead. This serves as a recovery drive and allows you to install Windows if needed in case the computer stops working.
    https://support.microsoft.com/en-us/windows/cre...
    https://www.yourwindowsguide.com/2021/09/create...
    Once you click Repair your computer option on the Installation Media, it will open the same options as Recovery Media.
    I hope that helps. Rely on us for any further inquiries. All the best.
    A Windows MVP writes content on the above website, so it is safe. However, do watch out for the ads. It should translate into your Browser language automatically.
    2026-05-01T15:53:46.7333333+00:00
    Use only supported methods and requirements for the Recovery Drive tool, and verify the USB meets what the tool expects rather than relying on manual pre‑formatting.
    1. Open the Recovery Drive tool correctly
      • From Start, search for Recovery Drive and select it, or run recoverydrive.exe.
      • In the tool, ensure Back up system files to the recovery drive is selected, then select Next.
    2. Let the tool handle the USB formatting
      • Connect the USB drive only when the tool prompts for a USB.
      • The tool will list eligible USB drives. Select the 32 GB drive and select Next.
      • Select Create and let the tool partition/format the drive as needed. Pre‑formatting to FAT32 is not required and can be ignored; the tool may reformat the drive.
    3. If the drive is still not detected
      • Ensure the USB is completely empty. The Recovery Drive process erases all data; use a drive with no important files.
      • If the drive has multiple partitions or special formatting, delete all partitions using Disk Management so the drive shows as a single unallocated space, then create a single simple volume and try again.
      • Try a different USB port (preferably a direct port on the PC, not through a hub) and avoid other USB storage devices while running Recovery Drive.
      • If available, test with another 32 GB or larger USB drive to rule out a device‑specific compatibility issue.
    4. Alternative for Surface devices
      • For Surface devices, instead of the generic Recovery Drive tool, download the factory recovery image from the Surface Recovery Image Download page and follow the Creating and using a USB recovery drive for Surface instructions. This process also requires an empty USB drive and will format it as needed.
    These steps align with the documented requirement that the Recovery Drive tool selects and prepares an empty USB drive itself and that any existing data or formatting on the drive will be erased.
