My device ran into a problem and couldn’t be repaired. Click or press Enter to see other recovery options.
Patrick Smallze 0 Reputation points
2026-08-26T12:58:47.3466667+00:00
How do I fix my home surface pro with this on my screen
Surface | Surface Pro | Performance and maintenance
  1. AI answer
    2026-08-26T12:59:00.6766667+00:00
    If the Surface shows Automatic Repair or a Recovery screen, use these steps in order:
    1. On the Automatic Repair screen, select Restart.
      • If Windows starts, install the latest Surface and Windows updates.
    2. If that does not work, select Advanced options > Continue.
      • This exits the recovery options and tries to continue to Windows.
    3. If the Automatic Repair screen appears again, select Advanced options > Troubleshoot > Advanced options > Startup Repair.
      • Follow the on-screen instructions so Windows can try to find and fix the problem.
    4. If the Surface freezes during Automatic Repair, use a USB recovery drive for Surface.
      • Shut down the Surface.
      • Insert the USB recovery drive into the USB port.
      • Press and hold Volume Down while pressing and releasing Power.
      • When the Surface logo appears, release Volume Down.
    5. If the device is stuck on the Recovery screen, the USB recovery drive steps are also the recommended reset path:
      • Insert the USB recovery drive.
      • Release Volume Down when the Surface logo appears.
      • Check whether Windows starts.
    6. If Windows still does not start after these steps, use a service option:
      • Send to Microsoft
      • Get in-person support
      • Self-repair if technically experienced and equipped for it
